8 members (Barkbark, TeddyAds, JoeSpeetjens, Robbie, Socalm3w, IcePack, ITP, Papaflump),
368
90
Topics49,849
Posts837,413
Posts: 21 |
My problem is when I switch on the leftside indicater lamp, the brake lamps on right and left sides start flushing. And when I turn on the ignition key the ignition lamp do not light up. When the engine is idling the ignition lamp do not light up, BUT as soon I run the engine, the ignition lamp lights up and don´t swich of before I switch of the engine. I hope someone understand me.
Posts: 2,539 |
Sounds like a grounding (earth) issue.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Blown lamps sometimes cause weird behaviour remove the indicator lamp and the tail brake lamp on the problem side see if symptoms change
Posts: 306 |
Check the rear earth wires
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
In this order, I would check: - Earthing points for lights - Bulb holders - The alternator wiring - The alternator
Posts: 898 |
No I agree a typical earthing problem.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Posts: 2,779 Likes: 5
Posts: 2,779 Likes: 5 |
yep, earth issue. To prove a point I'd run a separate and known good earth wire to the bulb holder/lamp.
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
Yes I'd be very surprised if earthing wasn't the cause.
When I ran my Reliant Scimitar GTE being a fibreglass body meant that each earth wire has to be a separate feed which caused many strange symptoms.
Well worth checking the main battery to engine earth out by bypassing it with a heavy duty jump lead.
Good Luck.
