2 members (Julian BB, Clipper), 262 guests, and 57 robots.
+8Rich 86
Topics49,846
Posts837,376
Hans K Offline OP
My problem is when I switch on the leftside indicater lamp, the brake lamps on right and left sides start flushing. And when I turn on the ignition key the ignition lamp do not light up. When the engine is idling the ignition lamp do not light up, BUT as soon I run the engine, the ignition lamp lights up and don´t swich of before I switch of the engine. I hope someone understand me.
Sounds like a grounding (earth) issue.
kirkusblog.com
1952 Ford 8N
Blown lamps sometimes cause weird behaviour remove the indicator lamp and the tail brake lamp on the problem side see if symptoms change
Mark - No Longer driving
Check the rear earth wires
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
Black Rat
Black Rat
check the bulbs first
Keith
2013 narrow bodied + 4 Ruby.
In this order, I would check:
- Earthing points for lights
- Bulb holders
- The alternator wiring
- The alternator
Costock, UK
Disco 5
E
E
No I agree a typical earthing problem.
+1 , earthing first
Originally Posted By John V6
+1 , earthing first
yep, earth issue. To prove a point I'd run a separate and known good earth wire to the bulb holder/lamp.
Yes I'd be very surprised if earthing wasn't the cause.
When I ran my Reliant Scimitar GTE being a fibreglass body meant that each earth wire has to be a separate feed which caused many strange symptoms.
Well worth checking the main battery to engine earth out by bypassing it with a heavy duty jump lead.
Good Luck.
