Topics49,853
Posts837,447
Posts: 6,538 |
Having seen the hand brake mechanism during build yesterday at the factory it really is a very basic system.
I would have hoped that his needs simple adjustment having bedded in?
Neil
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
It will no doubt improve as the pads bed in. The disadvantage of rear discs on a light car is that they don't do much so will take a while to bed in. Handbrakes on rear discs are known for being weak which is why some manufacturers incorporate a small drum in the disc for a handbrake. Apparently the VW electric handbrake has a motor in each rear caliper which applies the handbrake, rather than a tunnel mounted solenoid with cables. More to go wrong......
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
There are a few cars with rear disks and hand brake issues - Vauxhall Corsa and Honda Jazz are in this category. The issue I observed was this: - The handbrake was applied when the brakes were hot. - As things cooled down, the ratchet on the handle was sprung off leaving no parking brake applied. - The driver had (very foolishly) left the car on a slope and in neutral. Please don't ask me how I know this ............. Honest John has more: http://www.honestjohn.co.uk/askhj/answer...or-the-repairs-Please leave the car in gear when parked - we should all do this anyway.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Always leave a car in gear as a back-up. Years ago I learned this lesson when a cable broke and the car rolled off my drive....luckily it is a quiet road! I park in the garage without brake or in gear.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
What no Morgan monogrammed wheel chocks? standards are slipping!
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
It will no doubt improve as the pads bed in. The disadvantage of rear discs on a light car is that they don't do much so will take a while to bed in. Handbrakes on rear discs are known for being weak which is why some manufacturers incorporate a small drum in the disc for a handbrake. Apparently the VW electric handbrake has a motor in each rear caliper which applies the handbrake, rather than a tunnel mounted solenoid with cables. More to go wrong...... The Aero based cars have rear discs and a second, mechanical pair of calipers on each disk, just for the hand brake. A bit overkill, but very effective, they lock the wheels! But I rarely apply the hand brake, given that putting an automatic transmission in "P" is a rather more effective brake....
What no Morgan monogrammed wheel chocks? standards are slipping! Peter Chapman has one for his flat rad, on which the hand brake is, well, not a lot of use....!
Posts: 1,162 Likes: 5
Posts: 1,162 Likes: 5 |
this is not recommended by the likes of Mercedes, as the bit in the transmission that holds the car in place is not designed to act like a handbrake and not designed to handle the forces associated with it.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
OK on the flat, but not on a slope!
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Peter Chapman has one for his flat rad, on which the hand brake is, well, not a lot of use....! One wonders how it gets through the MOT? The 16% efficiency requirement is equivalent to holding the car on a hill just under 1:6, which is reasonably steep.
