6 members (Montegue, Laurens, Bitsobrits, TalkMorgan, jbk, Luddite), 276 guests, and 80 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,459
Page 5 of 6 1 2 3 4 5 6
SFO #349814 23/03/16 07:35 AM
Having seen the hand brake mechanism during build yesterday at the factory it really is a very basic system.
I would have hoped that his needs simple adjustment having bedded in?
Neil
SFO #349823 23/03/16 08:06 AM
It will no doubt improve as the pads bed in. The disadvantage of rear discs on a light car is that they don't do much so will take a while to bed in. Handbrakes on rear discs are known for being weak which is why some manufacturers incorporate a small drum in the disc for a handbrake. Apparently the VW electric handbrake has a motor in each rear caliper which applies the handbrake, rather than a tunnel mounted solenoid with cables. More to go wrong......
SFO #349878 23/03/16 11:28 AM
There are a few cars with rear disks and hand brake issues - Vauxhall Corsa and Honda Jazz are in this category.
The issue I observed was this:
- The handbrake was applied when the brakes were hot.
- As things cooled down, the ratchet on the handle was sprung off leaving no parking brake applied.
- The driver had (very foolishly) left the car on a slope and in neutral.
Please don't ask me how I know this .............
Honest John has more: http://www.honestjohn.co.uk/askhj/answer...or-the-repairs-
Please leave the car in gear when parked - we should all do this anyway.
Costock, UK
Disco 5
SFO #349883 23/03/16 11:36 AM
Always leave a car in gear as a back-up. Years ago I learned this lesson when a cable broke and the car rolled off my drive....luckily it is a quiet road!
I park in the garage without brake or in gear.
SFO #349933 23/03/16 04:05 PM
What no Morgan monogrammed wheel chocks? standards are slipping!
Mark - No Longer driving
DaveW #349972 23/03/16 06:34 PM
Formerly known as Aldermog
The Aero based cars have rear discs and a second, mechanical pair of calipers on each disk, just for the hand brake. A bit overkill, but very effective, they lock the wheels!
But I rarely apply the hand brake, given that putting an automatic transmission in "P" is a rather more effective brake....
milligoon #349973 23/03/16 06:35 PM
Peter Chapman has one for his flat rad, on which the hand brake is, well, not a lot of use....!
Peter J #349974 23/03/16 06:37 PM
SFO Offline OP
this is not recommended by the likes of Mercedes, as the bit in the transmission that holds the car in place is not designed to act like a handbrake and not designed to handle the forces associated with it.
SFO #349996 23/03/16 07:33 PM
OK on the flat, but not on a slope! smile
Peter J #350016 23/03/16 08:33 PM
One wonders how it gets through the MOT? The 16% efficiency requirement is equivalent to holding the car on a hill just under 1:6, which is reasonably steep.
