New
Topics48,365
Posts813,346
Members9,215
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
What are the UK regs for day light lights? I see my Roadster has pre dilled hole in the over riders which are quite low down.
Posts: 3,514 Likes: 8
Posts: 3,514 Likes: 8 |
You might notice I quoted the two conditions in which it is legal to use fog lights, depending in which part of the country you live this may mean you may never use your fog lights, or maybe a couple of dozen times a year, and even then their usefulness is questionable, dip beam often being better anyway, especially modern lights with a sharp cut off, so why do most modern cars have them, and if they were replaced by spot lights, correctly wired of course, would it then be legal to use them, even if fitted at the height of fog lights, an why?
Posts: 5,110 Likes: 56
Black Rat Charter Member
Posts: 5,110 Likes: 56 |
So, why is it illegal to use 'fog lights' placed in the same place as spot lights, unless there's fog or falling snow. Fog lights don't even dazzle. Fog lights do dazzle because they are set low and have a straight out beam. Spotlights have to go out when dip headlights are on, consequentially no dazzle.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
My front fogs basically light up the road for a SHORT distance in front of the car, hence useless as a dipped beam replacement, dipped headlights illuminate a good distance further ahead as per legal alignment requirements. Mine are fitted to the front of the wing...I am thinking of simply removing them and fitting spots as that is where spots rend to be anyway. Spots will give me better night vision when on main beam, despite my current bulbs being upgraded to Nightbreakers that give a small improvement only.
"My front fogs basically light up the road for a SHORT distance in front of the car, hence useless as a dipped beam replacement, dipped headlights illuminate a good distance further ahead as per legal alignment requirements."
Exactly, they only throw out light for a short distance, but more importantly for country road driving is the fact that they light up the edges well which is very useful, and I'm sorry Keith, I have to disagree with you about the dazzle, they don't throw enough light forward to dazzle, why don't you conduct some tests and see?
Exactly, they only throw out light for a short distance, but more importantly for country road driving is the fact that they light up the edges well which is very useful, and I'm sorry Keith, I have to disagree with you about the dazzle, they don't throw enough light forward to dazzle, why don't you conduct some tests and see? I think we will have to agree to disagree on this one, many of the fog lights fitted today do indeed dazzle.
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
What's also annoying on moderns is this new idea of switching on one of them when turning to illuminate close in to the vehicle on a corner. Twice I've not seen an indicator due to these...
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
If you are travelling in your Morgan at the speed of light and you turn on your spot lamps, would they light up?
Should I be travelling at the speed of light in mine I will know the world has ended... Or mine anyway
Posts: 4,608 Likes: 14
Posts: 4,608 Likes: 14 |
