4 members (Morganmike, Chris Cosher, SteveMerch, Ruut Bianchi), 323 guests, and 16 robots.
John V6 69
DaveW 64
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,348
Posts813,085
Members9,212
aeroed, DJC, James Mc, JimWhin
My Plus 4 has just had a new radiator fitted (from Williams) and everything looks fine. Running temperature is usually about 90-95 deg C as indicated by the temp gauge and I can hear the cooling fan cutting in and out.
Went out a day or two ago for the first proper drive of the year and did about 150 miles without any problem. Then I spent half an hour in heavy city traffic and the temperature rose to an indicated 120 deg C. The only way to get the temperature down was to turn the heater on full. After running outside the city for a while the temperature came back to normal. No sign of water leaks when I got home. When the engine is just ticking over the fan still operates at about 95deg C.
There are two relays for the fan – marked high and low on the wiring diagrams I found on TM – which I guess relate to fan speed. Is that right? And Is it likely that the high relay has failed? The relays are Tyco 0-1432793-1.
All suggestions gratefully received.
Plus 4 2-seater / 2.0 Duratec / 2011 / Amazon Green
Yes - two relays. It looks like the high speed relay may have failed. Try a substitution, but note that you need a relay with diode protection.
Also check the coolant level when cold.
It wouldn't be the first time a garage has missed a connection off the fan - it maybe worth checking first if you have not already done so.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Dave, Richard
Coolant and fan connections all look OK. Spares available from RS at 2.55 plus free delivery ( no connection with me!) - I will replace both relays and have a spare to be on the safe side.
http://uk.rs-online.com/web/p/products/7826953/?cm_mmc=UK-PPC-_-google-_-3_UK_EN_M_IP_and_E_Broad-_-te_connectivity|non_latching_relays&mkwid=s1dhSYO6W_dc|pcrid|78791998844|pkw|%2B1432793+%2B1|pmt|b|prd|&gclid=CIby5qKn3ssCFQWfGwodW50MFw#
There is a data sheet on this webpage which looks OK to me!
Thanks for your help
Good luck Conrad, Just reread your initial enquiry and noted the fan runs, sorry anno domini catching up.
2009 4/4 Henrietta
It comes to us all - I've already got it - that's why I have a mog!
Black Rat
Black Rat
I once spent nearly 2 K trying to cure the overheating on an Alfa only to discover it was a malfunctioning Temp Gauge. get an infra red thermometer (eBay about a tenner) and check the temp on the top hose next time it happens before you spend too much money.
Keith
2013 narrow bodied + 4 Ruby.
