10 members (TalkMorgan, hugo, RichB, Rex_tulips, Zach, RichardV6, RedThree, DaveK, howard, lez), 303 guests, and 41 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,332
Members9,215
#350675 26/03/16 10:07 AM
SBM Offline OP
Getting to grips with the car on an almost daily basis now, and wondered if there's a way to adjust the clutch and brake pedals to become a little more 'upright'..?
The brake pedal in particular feels to have too much inclination back towards me from the 90 degree upright position, where your heel contacts the bottom bracket.
It's not particularly easy to drive the car slowly in traffic as the motor skills needed are moved from the ankle and foot, up to the thigh and knee muscles which aren't used to the small movements.
Are the pedals adjustable for angle? I don't recall all cars being the same, from memory.
SBM #350679 26/03/16 10:32 AM
Probably possible but easier to just get used to floor mounted pedals Steve.. they have a very different 'action' to the more familiar set up..
I once had to drive a car with the throttle pedal in the middle..now that was weird.
I'm sure some of the fabricators on here could maybe adjust the angles but i reckon it'll be a faff to get it right..
SBM #350686 26/03/16 11:31 AM
It's theoretically possible to fit spacers between the chassis rail and pivot tube mountings but you would need to establish the effect on master cylinder travel. That would bring the pivot closer and rotate the pedal further towards vertical.
SBM #350693 26/03/16 12:04 PM
I was all over the place with de-clutching and braking when I first got the Plus 4 but it feels just right now. I'd give it all a bit longer then re-assess. We are all different though!
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
SBM #350694 26/03/16 12:06 PM
A simple solution: glue (or bolt) some rubber, plastic or wood onto the two pedals.
They are more "upright" in your direction than.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
How would that work, they'd be tilted further forward surely?
Mark - No Longer driving
SBM #350704 26/03/16 12:53 PM
Sorry, had a different picture in mind.
Went down to the garage to have a look ... my idea will not work
Edit: has anyone got an idea where the washer could have fallen off?
Hannes
SBM #350709 26/03/16 01:21 PM
Steve,
It may depend on what car you've got but on my 07 +4 you can get some adjustment on the brake pedal by moving the clevis on the servo push rod. Loosen the clevis locknut. Take out the split pin and clevis pin. You can then screw the clevis further on to the servo push rod. Replace pin and split pin, then tighten the lock nut. This may be enough to get the brake pedal in line with the throttle. You may have to adjust the brake light switch afterwards.
Cheers
SBM #350711 26/03/16 01:28 PM
If the washer has fallen off then a nut must be some where too?
Given its size and position I would look around the area where the steering column assembly is held to the bulkhead behind the tubular cross member framework
SBM #350724 26/03/16 02:19 PM
No intention to hijack this thread - but I found the location for the washer and the nut. Had to fix 6 loose nuts in the neigborhood too. Not a lot of space available there for a grown up guy.
Hannes
