9 members (stefan s, John V6, MATTMOG, DavidR, Morganmike, Paul F, Alan Patterson, xc68anc, DCH), 287 guests, and 46 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,397
Members9,215
Rbt Aero8, Salmon, stevends
#351284 28/03/16 11:43 AM
Rev 4K Offline OP
I have a morgan based project on the go. I need to glue an aluminium block to an aluminium sheet. I have tried araldite on a properly cleaned and scored surfaces but it has failed. Is there something else out there that is better? It needs to be obtainable from the usual sources
thanks in advance.
2004 Silver Roadster S1
Rev 4K #351285 28/03/16 11:51 AM
Lumiweld?
'09 Gen2 MINI Cooper ragtop
Rev 4K #351287 28/03/16 12:05 PM
2015 Plus 4 (GDI) Sport Green
Rev 4K #351289 28/03/16 12:10 PM
How much strength is needed ?
I have used JB Weld on fairly low stressed fixings and added brackets for extra strength use where possible.
The key (excuse the pun) is surface prep, clean and roughness/smoothness of mating surfaces being important.
Rev 4K #351290 28/03/16 12:26 PM
Did you use Araldite metal repair?
Or just the standard epoxy?
Depending on size of block and sheet why not drill tap and use a countersunk screw?
Mark - No Longer driving
Originally Posted By athelstan
That's the other one I couldn't remember... doh
Rev 4K #351296 28/03/16 01:03 PM
Believe it or not I have used JB Weld on a cast iron exhaust manifold back in the day. It was on a Rover V8 and a couple of the flanges had broken off.
Not only did it stick the metal together, when I replaced the manifolds with tubulars, the cast maifolds were still intact and I sold them on, and they continued to hold.
Remarkable because this is well outside the performance envelope.
JB Weld is probably the highest temperature epoxy resin glue - certainly was when I looked into the issue. Good enough for a non-combustion chamber repair to an engine block.
There are two grades of Araldite, the stuff that sets in few minutes, and the traditional wait 24 hours one. The latter is of course stronger, but the quick one has its uses for things one might want to take apart again as if you can boil the object in detergenty water, the epoxy becomes like cheese.
But you'll never have any success with any kind of glue if you don't thoroughly degrease the surfaces first. I generally tell folk, 'do it properly, and then do it again'. Epoxy should stick aluminium no problem, and without trying for myself, I would suspect a surface that was still slightly greasy in the event of failure.
Rev 4K #351299 28/03/16 01:14 PM
Rev 4K Offline OP
Thanks chaps. i will try JB Weld and see how it goes.
Rev 4K #351321 28/03/16 02:25 PM
3m panel adhesive is the only thing I could recommend... it is designed specifically for what you are doing, it is used to bond new cars together as well as for the bodywork industry to do repairs.
http://3mcollision.com/3m-panel-bonding-adhesive-08115.html
kirkusblog.com
1952 Ford 8N
