3 members (Camelot, WJH, +8Rich), 283 guests, and 40 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
#351486 29/03/16 11:58 AM
B3MOG Offline OP
i have 4 pot front brakes and rear disc brakes on my 1985 +8inj. where can i get a larger diameter master cylinder (twin line system) or will i have to fit two separate cylinders and a balance bar. The reason for doing this is to eliminate too much pedal travel.
David Byrne
B3MOG #351497 29/03/16 01:04 PM
Does your master cylinder have an integral fluid revervoir? I suspect that it will have.
Without knowing the specifics of your set-up, I suspect that your 'long' pedal is due to the kick-back associated with your rear disks.
I have dual master cylinders with balance bar adjustment. The cylinders are Girling cylinders of different bore size to get the front/rear balance close. The balance bar is for fine tuning for dry and wet braking.
I suggest that you approach a Morgan specialist with race car set-up experience. Alternatively, you can PM me for details of my car's spec, etc.
B3MOG #351514 29/03/16 02:57 PM
+8 1976
B3MOG #351516 29/03/16 03:08 PM
Hi Manuel, your car is the same year as mine. I have good friends that live in Rendsburg; they own an original, un-marked 1980 Plus Eight.
B3MOG #351535 29/03/16 04:02 PM
I read the thread as I was about to suggest speak to Peter Mulberry.
BR Colin
B3MOG #351578 29/03/16 06:15 PM
For what it's worth, the parts illustrated on Mulfab's website are very similar to those fitted to my car so I'd also recommend speaking to Peter Mulberry.
B3MOG #351602 29/03/16 08:30 PM
B3MOG Offline OP
Thanks for the information I will give Mulfab a ring, I realise they supply the parts but do they also carry out the work?
David Byrne.
