8 members (Alan Patterson, John V6, Moggo, Barkingdog, RichardV6, Craig Jezz, JohnHarris, nick w), 248 guests, and 29 robots.
+8Rich 84
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,364
#352789 03/04/16 11:42 AM
Ladies/Gents,
My '97 (hot wire) Plus 8 electric radiator fan has become rather noisy - I suspect the bearings. Looking to buy a new unit (13") but would like to find a quieter running unit without loosing the cooling efficiency. See a lot of different designs with different cfm throughputs, amps, blade shapes etc., but not sure which would suit best - anyone been through the same search an got a good result? Much appreciated. Kevin
Send Me your Email address and I will try to help. wmbutton@gmail.com
Button
Seattle
Button
Kevin,
Has the fan become more noisy compared to the past? Mine makes a real din when working , it is far louder than the exhausts on tickover.
I seem to remember that current thinking is to use a Spal fan, but I don't have a reference number for the correct one. Here is some information: Click here
Do not skimp on the wiring, the fan can pull 20 amps, and the standard wiring is not man enough for this , so upgrade and make sure you use a good quality relay.
Andy G
1999 +8 , Indigo Blue.
I have Spal VA08-AP13-53S 1800 CFM at 13 volts. It is a pusher. I purchase a Spal relay temp control fed by a #10 wire and a 20 AMP fuse. It is hard wired not switched. There is an adjustment knob to regulate the temp it turns on. However; when climbing a long steep hill at 70 MPH on a hot day the temp climbs to the boiling point and higher. I must slow down to about 50MPH if I am going to keep going. This happens to the +8 Bitsa very rarely but it does happen. I sometime think that this fans acts as a blocker at 70 MPH.
Button
Seattle
Button
Pusher vs Puller Spal electric fan. I installed a Pusher Fan because it is easy to do. A Puller is probably more efficient way to go. I have attached a file. This is an idea of another that I have used on My DHC. So far so good
Button
Seattle
Button
The Flex-A-Lite fan is 1,250 CFM.
Button
Seattle
Button
OOPS! I posted page 13 but not 14. Will get this done ASAP.
Button
Seattle
Button
Button
Seattle
OK here is page 14
Button
Button and MOG 615,
Thanks indeed for the prompt advice - as mentioned by MOG 615, the current unit has always made a decent whirrrr sound, but recently accompanied by a slight rattle (more evident when I switch-off). The current unit is a pull unit and although it comes on at circa 80C and stays there (even in mild whether), it seems to do a decent job as it rarely goes above 90C and, aside from the din has been good. The unit is manufactured by Kenlowe Group. The previous owner seems to have had a lot done with wiring and it has a decent size relay with a 20amp fuse. Nonetheless the wiring shows things can get pretty hot - need to do some work there too. Hmmmm Kevin
Gents
Been doing some more digging...Unit is a Kenlowe KLM 1708 12 Volt - so I guess I'm looking for something of similar capacity but quieter.... Thanks again. Kevin
