10 members (Soleng, DCH, DJC, Ncik P, eds, Ritchie B, DaveW, Luddite, Mike D, TalkMorgan),
300
35
Topics49,837
Posts837,286
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
On my 2006 the switches are locked at the back of the pcb. Check it is properly connected first
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Phone Melvyn again. They can chase things up for you. They have regular deliveries from the factory so if the factory has the pcb unit in stock it won't take long( don't quote me!) Melvyn is helpfull and will chase it up for you.
Posts: 202 |
Just had a call from Graham at Rutters.
I need to check the Morgan part reference number on the board. He thinks it is MDE 4001.
Does this sound familiar to anyone who has replaced their board/s?
-------------------------------------- Regards Bob
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
http://www.talkmorgan.com/ubbthreads.php/topics/291718/Morgan_RoadsterGoing by this thread it seems to be right but there would also seem to be different versions. In the 2006 + parts book it is not listed. You are welcome to a pdf of the Parts book - pm if you would like a copy.
Looks like you need to get at the unit to find the number. Unless it is mounted where you can see it behind the dash then it is a dash off job. I had to do that to get at mine on the 2002 Plus8. It was screwed to the ash frame high up. If you do that then take photos as you do the job. With the dash removed you will then have photos of the layout of all units etc. The case of the pcb unit may or may not have any ID on it....mine didn't! GRRR. I opened the case up and checked the interior...take care! Photos taken of interior etc and hot melt glue to replace the cover. I sent the photos to Graham at Melvyn's. In the end I managed to fix mine, bit of luck really.
Does this sound familiar to anyone who has replaced their board/s? What year is yours ? I have my failed 2006 unit at home & can look to see if it has a part number but only on Friday as I am in Germany this week
Posts: 202 |
The car is a 2012 plus4.
Thanks for your help.
Doh!! Just saw the thread title. OK then it is a different design, sorry
Posts: 202 |
Until a replacement board is sourced, a by pass switch now installed.
Thanks for all suggestions.
