6 members (RichardV6, +8Rich, Julian BB, TalkMorgan, Montegue, Jon G4LJW), 299 guests, and 83 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,452
Some pics of my new MK dash with MorganPark stalks
[url=[URL=http://s1187.photobucket.com/user/Bianchi161/media/12993512_1003641199716711_7469512184940345713_n.jpg.html][/url]]New MK dash[/url]
16 Comments
See also this thread!
http://www.talkmorgan.com/ubbthreads.php/topics/355166/Re:_New_Matthias_Kauffelt_dash#Post355166
I gave the Morgan a good clean after I collected her at Klaas Booij in the Netherlands. The new MK dash looks lovely, the switches feel solid and the new MorganPark steering column stalks operate, feel and look fine. It was quite a bit of work installing the refurbished stalks, very little space with also the new SS cover. But in the end: a good result!
Ruut Bianchi
I do like that centre panel, that rotary light switch in particular looks very smart.
BR Colin
That is very nice indeed.
It has a classy 60's Jaguar look to my eye.
Indeed, the rotary light switch is a 60's, or even earlier, one from a Jaguar. The whole set up looks really nice, well done.
Reg
This switch is MK's interpretation of the old Jaguar switch. I you use it you wonder why they ever changed such switches....!
Ruut Bianchi
Your volt meter seems to be registering about 11.5v. Is it on all the time, or is your ignition switched on?
Cost I suppose Ruut, my Grandfather used to run a MKX Jaguar with twin fuel tanks and the changeover switch was a similar type from memory.
John, that happened a long time ago after I had little holes drilled in the 4 central meters to prevent them from damp inside. It didn't work out well, and after that the voltmeter never returned to zero if ignition is of. But for the rest it seems to function well for many years already, so I left it that way.
Ruut Bianchi
Very classy!
