7 members (Image, MavisTheMorgan, Gramrugby, sewin, Grumpy2, sbarracl, Biggle), 198 guests, and 31 robots.
+8Rich 92
Topics49,838
Posts837,294
Page 1 of 5 1 2 3 4 5
#356794 17/04/16 02:58 PM
E
Eddie Offline OP
E
I've owned my ARP4 about three weeks and in the main I like it.
I can put up with the noise, just! but not the complete lack of any effective handbrake.
If I pull the handbrake lever as hard as I can the car is not braked in any way.
I can step out of the car with the handbrake fully on and push the car along with one hand!
The car cost me approximately £62950 and for Morgan to sell this car in such a state is an absolute disgrace.
The car being only three weeks and it certainly wouldn't pass a MOT.
I understand other ARP4 owners have similar gripes about their handbrakes and I wonder if their's is as bad as mine.
I would be interested to hear comments about how we should progress the matter.
Eddie Hayden
Eddie #356799 17/04/16 03:15 PM
E
E
My aero 8 had the same problem, handbrake was useless!! I think it is due to the discs at the rear, my plus 4 has rear drums and the handbrake is super!!
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Eddie #356801 17/04/16 03:19 PM
Hi Eddie, sorry to hear that you have a problem with the effectiveness of your handbrake. This is not a flippant suggestion, get it back to your dealer and ask them to resolve for you.
In the meantime when you park up, stick it in gear to hold it.
I seem to remember when car began to get rear disc brakes, whose handbrakes were ineffective the advise was to apply the handbrake for the last smidgen of movement. just a thought.
As said above get it booked into your dealer.
Ian
Eddie #356811 17/04/16 03:45 PM
SBM Offline
Eddie,
I agree with Wirewheel, the contract is between you and your dealer so let them satisfy you.
It may be that something's not quite right with yours, or that it's being influenced by something else, but they need to have the opportunity to get it sorted for you.
I have a lovely vision in my mind of you going shopping being slowly followed by your car like a dog on a lead..
It needs sorting, chum.
Eddie #356813 17/04/16 03:47 PM
Ditto. The disc handbrake on my Merc is fine. Go back & complain they shouldn't have sold it like that.
Eddie #356817 17/04/16 03:53 PM
I have a Toyota Hilux Invincible which is a very heavy vehicle, it has superb brakes, discs in the front and drums in the rear. I believe that the reason for fitting the drums at the rear is because if the rear was discs then after applying the handbrake to the discs they would eventually cool and contract and the handbrake will become ineffective, so you could walk away from the vehicle and come back later to find it had moved.
Of course this does not answer the problem of why the handbrake on the ARP4 doesn't work when applied to a cold set of discs.
"Hasta la victoria siempre"
Eddie #356839 17/04/16 05:11 PM
I don't know the rear disc pad arrangement on the ARP4, does the handbrake actuate the same pads as the footbrake, or is there a separate set?
The reason I ask is that if the handbrake uses the main pads, then it might help to apply the footbrake when applying the handbrake. This is the way it works on my tractor, the handbrake mechanism isn't designed to apply full braking force on its own, it just holds the pads in position once the footbrake has been released.
The effect is really noticeable on my tractor, the handbrake is crap if you just use it on its own, but put your foot on the brake and then use the handbrake and everything is tickety-boo.
Eddie #356845 17/04/16 05:20 PM
On my Merc they are separate discs & I thought in general they usually are as one is hydraulic & the other cable actuated
Eddie #356872 17/04/16 06:14 PM
Some cars with rear discs also have a small drum brakes for parking, often built into the hub of the disc.
Eddie #356874 17/04/16 06:19 PM
I believe this is a Morgan design problem, one way or the other.
When I took mine to Berrybrook for its' first service and complained about the handbrake, they said they could do nothing further, but they offered Tims suggestion about applying the footbrake first, then on with the handbrake, which in fairness, does seem to work, though I have yet to try it on a hill, but I will.
BTW for those who don't know, there is only one pad on Morgans setup and this works footbrake and handbrake, probably from a Ford Sierra or Sierra Cosworth.
I have some rust on the inside area of the discs, which indicates that the pads just aren't gripping, even using the footbrake in the normal way, but as they bed in it will probably get better.
Discs can be made to work, and work well, especially with a short cable run, as we have in Morgans. Maybe more leverage is required, I don't know?
