2 members (DavidR, linklaw),
103
Old Book
Topics49,940
Posts838,603
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 12,284 Likes: 329
Posts: 12,284 Likes: 329 |
I confess I have no idea of MMC's specified torque setting (if indeed there is one), but you may find this guide to torque values useful
Posts: 22,386 Likes: 359
Posts: 22,386 Likes: 359 |
Don't go mad Keith. It draws into the taper. I just use a short ring spanner with a good pull. Probably 20 - 25 lbs ft? Hard to judge.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I confess I have no idea of MMC's specified torque setting (if indeed there is one), but you may find this guide to torque values useful That is a really useful guide Tim , but I think I would lose the will to maintain my car if I had to look it up on those tables every time. I have found Autodata to be a useful source for cars that I am not yet familiar with and before I get a workshop manual.
Yup, me too! I don't normally worry about calculating an exact setting, I just use a value appropriate to the size range of the bolt. I only ever use a torque wrench on the important stuff, and the really important stuff is tab washered, lockwired, or pinned.
Posts: 898 |
Agreed with Dave, a good pull on a short ring spanner but a bit short of a first grunt.
Posts: 1,947 |
While some torques do matter, the general principle is to do a nut up to short of the elastic limit of a bolt, or to a lesser degree that does not distort either of the surfaces being joined. And if more than one bolt is used, to get all of them done up to the same degree.
If one has a medium length selection of spanners, the length is usually dictated by the sort of torque that is expected with the use of high tensile fastenings to join components of a solid steel.
A set of long handled spanners used for doing stuff up could well overtighten, but are handy for getting things undone.
Thanks all to 'Torque Morgan' for setting me straight.
Keith
Posts: 6,538 |
I learnt the joys of a torque wrench when I was racing.
It was a great piece of kit.
Needless to say I loaned it out and never saw it again!
Neil
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
