0 members (), 135 guests, and 31 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Clock Offline OP
The paint is starting to rub onto the bottom of the PVC sidescreens;
I realise that it's my fault for having the such a stylist combination of green and cream but... anyone got any advice on how to clean it off the PVC and also prevent it occurring again?
WD40 will take it off the PVC. I think that the problem starts at the factory when the sidescreens are mounted before the lacquer has had time to harden properly.
In addition, the sidescreens are constantly chafing against the paintwork with the accompanying noise. I tried foam rubber pads and no doubt Mr Neoprene will have found a solution using his favourite material and will be along here shortly.
jbk Offline
Might be worth buying self adhesive baize from ebay in cream (or Stone) to lessen paint damage. As its distinctive shape you could take a tracing of the contact area.
When the paint has hardened (if it does) you can remove baize with white spirit.
1993 T16 +4 Lancia Blue.
What about some anti-chip film on the paintwork?
Gerry
Yes paint protection film. I've done that on both mine and really it should be standard. Obviously it doesn't photograph well but when I do the next car I'll post a how to. They also benefit from protector along the bottom edge of the body tub where the doors can rub the paint away.
Clock Offline OP
Thanks for all the responses
I use protection film where I can
There was a guy advertising Volvo anti squeak tape....which I think is clear, in the back pages of Miscellany....that might work.
That's a bonnet tape substitute. (I prefer neoprene/leather). Clear film is better on the "B post".
Bonnet tape replacement.
Advertiser is the MSCC's Competition Secretary... smile
