5 members (RubyMog95, RichardV6, Ian Wegg, Simon, Jon G4LJW), 236 guests, and 73 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
O
oylo Offline OP
O
The steering wheel is not centered between my main instruments.
Is it possible to adjust the shaft on the steering wheel about 1 inch toward the middle of the car?
[img]http://i448.photobucket.com/albums/qq205/talkmorgan/IMG_4443_zps8p3ujhuj.jpg~original[/img]
Steering wheel
2005 4/4.
I am able to take a nut off and adjust the steering wheel. But these are older Morgans. I like the steering wheel not centered because I can see the speedometer thru the spokes.
Button
Seattle
Button
Look under the cowl the wheel is bolted to the bulkhead.
The bolt holes on the steering column support are slotted to allow left to right movement I think from memory
I'm thinking of moving a steering wheel about 3 foot on a car that Allon White are selling.
Best Regards
Lang may yer lum reek
CBY Offline
You don't have to adjust the shaft on the steering Wheel, but the opposite: adjust the steering wheel on the shaft.
Under the horn hub, unscrew the nut (item 5) page 105. The steering Wheel is fixed on splines and a cone (page 30). With your steering Wheel there is an interface part between the steering Wheel and the shaft.
http://www.morgan-cars.com.cn/wp-content/uploads/2013/02/morgan-traditional-parts-book-2006.pdf
Perhaps misunderstanding? What do you want to move, steering wheel or shaft?
Regards
2005 PLUS 4
Yes, this the way to go.
