0 members (),
503
53
Topics49,841
Posts837,323
GaB
Unregistered
GaB
Unregistered
Hello from showery Worcester, just 10 miles from the shrine of Pickersleigh Road. There is a wealth of knowledge on TM; I have already found it invaluable, and very addictive, or infectious (morganitis)!
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Welcome to the forum. Any pics yet?
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 1,516 Likes: 60
Posts: 1,516 Likes: 60 |
Welcome to the fold. I can think of very few more memorable events than the "Barn Find". Its happened to me twice - but both were long ago when such hidden jems were not quite so rare. The memory is still fresh nonetheless. No 1. Spotted a small western morning news advert. No 2. A word of mouth tip off.
Posts: 12 |
Thanks for all the above, I did collect the car today and it's home in the Garage. (I'm in Epping) I have started taking some pics, I assume I have to post on the web somewhere then add a link? One quick question before I start a post on technical, is there an easy/ quick way to remove the bonnet when working on the engine, it seems very fragile with one half open?
1983 Plus 8 (on carbs) 1975 Land Rover 109" full tilt 1989 Caterham 1999 Honda Fireblade
Posts: 168 |
There is a brass bracket which holds the front of the bonnet hinge, attached to the cowl. Remove it by undoing its two screws, pull the bonnets forward a little out of the rear brass bracket, and the whole lot lifts off. A bit fiddly, but worth doing if you have serious under-bonnet work to do.
Fjemog
1993 Plus 8
Posts: 4,896 |
You need bonnet stays from Wolf Performance
Adrian
GaB
Unregistered
GaB
Unregistered
I echo Adrian's comment: buy Wolf Performance bonnet stays. Do not buy the inferior version I have (but now regret).
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
There is a brass bracket which holds the front of the bonnet hinge, attached to the cowl. Remove it by undoing its two screws, pull the bonnets forward a little out of the rear brass bracket, and the whole lot lifts off. A bit fiddly, but worth doing if you have serious under-bonnet work to do. To be safe ,its a two man job.
Posts: 58 |
Hi, that is a brave start, I'm looking forward to the pictures
Ash Green 4/4 ~ 2013
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Re removing the bonnet. Do as mentioned above. I lay a blanket down the middle along the chrome hinge, open both sides and then bungie cord the two halves together, using the bonnet knobs. Is is then a bit more manageable removing by yourself. Still best with two folks.
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
