0 members (), 365 guests, and 89 robots.
Topics49,847
Posts837,389
GaB
Unregistered
GaB
Unregistered
Hello from showery Worcester, just 10 miles from the shrine of Pickersleigh Road.
There is a wealth of knowledge on TM; I have already found it invaluable, and very addictive, or infectious (morganitis)!
Welcome to the forum. Any pics yet?
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Welcome to the fold.
I can think of very few more memorable events than the "Barn Find". Its happened to me twice - but both were long ago when such hidden jems were not quite so rare.
The memory is still fresh nonetheless.
No 1. Spotted a small western morning news advert.
No 2. A word of mouth tip off.
cheers
Graham
Octogenarian - (82)
1.8 4/4 Ivory
ToyoYarris
VolvoV70
Thanks for all the above, I did collect the car today and it's home in the Garage.
(I'm in Epping)
I have started taking some pics, I assume I have to post on the web somewhere then add a link?
One quick question before I start a post on technical, is there an easy/ quick way to remove the bonnet when working on the engine, it seems very fragile with one half open?
1983 Plus 8 (on carbs)
1975 Land Rover 109" full tilt
1989 Caterham
1999 Honda Fireblade
There is a brass bracket which holds the front of the bonnet hinge, attached to the cowl. Remove it by undoing its two screws, pull the bonnets forward a little out of the rear brass bracket, and the whole lot lifts off. A bit fiddly, but worth doing if you have serious under-bonnet work to do.
Fjemog
1993 Plus 8
Drive on the Wild Side
You need bonnet stays from Wolf Performance
Adrian
GaB
Unregistered
GaB
Unregistered
I echo Adrian's comment: buy Wolf Performance bonnet stays.
Do not buy the inferior version I have (but now regret). frown
Ray Offline
To be safe ,its a two man job.
Hi, that is a brave start, I'm looking forward to the pictures smile
Ash Green 4/4 ~ 2013
Re removing the bonnet. Do as mentioned above. I lay a blanket down the middle along the chrome hinge, open both sides and then bungie cord the two halves together, using the bonnet knobs. Is is then a bit more manageable removing by yourself. Still best with two folks.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
