10 members (Graham, G4FUJ, cerealsurfer, DCH, High Hamster, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds, sewin),
303
64
Topics49,860
Posts837,522
Posts: 44 |
Hi, does anybody know how to replace the H4 main beam bulbs in a 2010 Roadster? Is it really necessary to dismantle the head light unit or can one access the bulb from the wing? Appreciate your advise...
Karsten
2010 Teal Roadster Sport V6
Posts: 1,127 |
Hello & welcome to the Forum "231"! You´ll have to dismantle the chromed trim/ring and the lens/reflector combination too to get to the bulb. On the other hand you could cut a BIG hole in your car´s wing from underneath, which nobody (??) here would recommend you to do
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 44 |
Hi Numog, tahnks for your quick reply which confirms what I feared. Hope afterwards the lights do not need to readjusted... And the big hole in my beautiful wing, noooo
Karsten
Posts: 168 |
The chrome ring is held on by a small cross head screw usually close to the 6 o'clock position, it may require a stubby screwdriver (or right angle) to get at it.
The lamp unit is removed by taking out the (I think 3) retaining screws, be careful you do not touch the lamp position adjusting screws. A piece of white masking tape can be used to mark the glass unit's position in the headlamp well to aid in reassembly.
You may find that there is a sticky rubber gasket/foam which will need to be carefully separated.
Place a towel/blanket to rest glass unit on while you pull off the rear H4 connector and replace bulb.
Posts: 1,127 |
No re-adjusting required if you just unscrew the items & put them back the same (IF the lights were set correctly before start that is!)
Posts: 2,814 |
I'd also suggest marking the position of the outer ring screw, before you remove it.
Gerry
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
A really simple job even I managed it, why not fit Nightbreaker bulbs while you're at it makes a huge difference.
Posts: 44 |
many thanks for your comments/recommendation. I will try the Osram Nightbreaker and will mark everything carefully...
Karsten
Posts: 5,655 Likes: 4
Posts: 5,655 Likes: 4 |
many thanks for your comments/recommendation. I will try the Osram Nightbreaker and will mark everything carefully... I brought mine from Euro car parts for £17.00 Inc. vat for the pair
Martin (Deano)
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
In many years of changing bulbs or sealed beam units I have never had them go back in without needing realigning - not difficult to do...
