5 members (Pundit, TBM, Zach, piquet, TeddyAds), 362 guests, and 65 robots.
+8Rich 79
DaveW 50
Topics49,866
Posts837,588
A garage door and a bit of patience is all that's required.
Exactly! smile
Exactly! smile
The full instructions for this are in my car handbook I noticed the other day. thumbs
When I blew a bulb I was not able to mark the old beam position on the garage wall so I found as much as I could on Google and used those dimensions.
I though they looked correct, but when I took it for a MOT it failed!
Does anyone have the correct dimensions for setting up the headlights (in case I need to do it again)?
I have no idea what the precise dimensions are, I have always used the following method:
1. Park car on a flat surface as close as possible to a wall or garage door.
2. Make a chalk mark exactly opposite the centre of each lens
3. Reverse the car back 15 feet or so
4. Strike a vertical chalk line through each spot, and a horizontal line that goes through each spot
5. Adjust the main beams so the bright spots are on the centre vertical and just below horizontal
6. Check the dips throw the light to the left and below.
It's probably wrong, but I've never failed an MOT yet on poorly adjusted lights. You could probably spend ages on precise adjustment and get a better throw up the road, but I don't drive fast at night, there are two many animals to look out for.
Remember that on the traditional 7" bowl headlights, you shouldn't have to touch the adjusters to get the retaining ring free, it's held by just the little screws that go through the flange pieces with the cutout. Slacken them off, and you should be able to twist the retaining ring free. Dosing all the threads with ACF50 is a good idea.
Great instructions, thanks Tim
