8 members (GrumpyPa, Sir Percival, Alistair, TBM, Morganmike, DPEvans, ChrisMorgan, piquet),
294
Topics49,842
Posts837,331
GaB
Unregistered
GaB
Unregistered
Hello from showery Worcester, just 10 miles from the shrine of Pickersleigh Road. There is a wealth of knowledge on TM; I have already found it invaluable, and very addictive, or infectious (morganitis)!
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Welcome to the forum. Any pics yet?
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 1,518 Likes: 60
Posts: 1,518 Likes: 60 |
Welcome to the fold. I can think of very few more memorable events than the "Barn Find". Its happened to me twice - but both were long ago when such hidden jems were not quite so rare. The memory is still fresh nonetheless. No 1. Spotted a small western morning news advert. No 2. A word of mouth tip off.
Posts: 12 |
Thanks for all the above, I did collect the car today and it's home in the Garage. (I'm in Epping) I have started taking some pics, I assume I have to post on the web somewhere then add a link? One quick question before I start a post on technical, is there an easy/ quick way to remove the bonnet when working on the engine, it seems very fragile with one half open?
1983 Plus 8 (on carbs) 1975 Land Rover 109" full tilt 1989 Caterham 1999 Honda Fireblade
Posts: 168 |
There is a brass bracket which holds the front of the bonnet hinge, attached to the cowl. Remove it by undoing its two screws, pull the bonnets forward a little out of the rear brass bracket, and the whole lot lifts off. A bit fiddly, but worth doing if you have serious under-bonnet work to do.
Fjemog
1993 Plus 8
Posts: 4,896 |
You need bonnet stays from Wolf Performance
Adrian
GaB
Unregistered
GaB
Unregistered
I echo Adrian's comment: buy Wolf Performance bonnet stays. Do not buy the inferior version I have (but now regret).
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
There is a brass bracket which holds the front of the bonnet hinge, attached to the cowl. Remove it by undoing its two screws, pull the bonnets forward a little out of the rear brass bracket, and the whole lot lifts off. A bit fiddly, but worth doing if you have serious under-bonnet work to do. To be safe ,its a two man job.
Posts: 58 |
Hi, that is a brave start, I'm looking forward to the pictures
Ash Green 4/4 ~ 2013
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Re removing the bonnet. Do as mentioned above. I lay a blanket down the middle along the chrome hinge, open both sides and then bungie cord the two halves together, using the bonnet knobs. Is is then a bit more manageable removing by yourself. Still best with two folks.
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
