6 members (Zach, Paul F, lez, stumog, BobtheTrain, Image), 353 guests, and 47 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
#362040 06/05/16 10:33 AM
I've noticed that my tacho occasionally sticks (even with the ignition off) at about the 1500 rpm mark. Is this one of those "they all do that sir" or should I get it looked at? Thanks
Which year/model.
Have heard this happening to some newer ones.
If I tap the glass on my tacho, the needle will drop below the 0 point.
My Roadster speedo has a nervous twitch at tick over.
Online NoMood
Went for a quick blast yesterday to get a keyboard and mouse and when I started the Mog, the speedo went round the clock and back. It gave correct readings when driving afterwards, though.
Best Regards
Lang may yer lum reek
What make of Tacho is it. Smiths, VDO or something else.
David
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
It's a Smiths tacho, 4/4 built 2014 if that's any help
My 4/4 does it sometimes when I turn the ignition back on it returns to zero .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
Excuse me for using this thread for my question!
Is there any photo from the back of a SMITH Tachometer (2005/2006 4/4) I want to know how the connector with the harness is fixed (secured) to the tachometer.
Black Rat
Black Rat
When you start the engine make sure you wait until the ECU has cycled. Wait for all the dash lights to come on and go off and if you have an immobiliser light wait for it to go out. If not the tacho will do all sorts of silly things.
Keith
2013 narrow bodied + 4 Ruby.
Hi, have a look at one of DaveW's posts. It is titled Mr Bumble Improvements -Phase 3,
dated 09/10/13 04.38pm, there you will see a picture of the rear of a Smiths tachometer,
It is from a newer car, however it may well be the same as your tacko.
Ian
