Topics49,843
Posts837,336
Posts: 99 |
I've noticed that my tacho occasionally sticks (even with the ignition off) at about the 1500 rpm mark. Is this one of those "they all do that sir" or should I get it looked at? Thanks
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Which year/model.
Have heard this happening to some newer ones.
Richard 1976 4/4 4 Seater
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
If I tap the glass on my tacho, the needle will drop below the 0 point.
My Roadster speedo has a nervous twitch at tick over.
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
Went for a quick blast yesterday to get a keyboard and mouse and when I started the Mog, the speedo went round the clock and back. It gave correct readings when driving afterwards, though.
Posts: 306 |
What make of Tacho is it. Smiths, VDO or something else.
David
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 99 |
It's a Smiths tacho, 4/4 built 2014 if that's any help
Posts: 305 |
My 4/4 does it sometimes when I turn the ignition back on it returns to zero .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Excuse me for using this thread for my question! Is there any photo from the back of a SMITH Tachometer (2005/2006 4/4) I want to know how the connector with the harness is fixed (secured) to the tachometer.
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
It's a Smiths tacho, 4/4 built 2014 if that's any help When you start the engine make sure you wait until the ECU has cycled. Wait for all the dash lights to come on and go off and if you have an immobiliser light wait for it to go out. If not the tacho will do all sorts of silly things.
Posts: 3,643 |
Excuse me for using this thread for my question! Is there any photo from the back of a SMITH Tachometer (2005/2006 4/4) I want to know how the connector with the harness is fixed (secured) to the tachometer. Hi, have a look at one of DaveW's posts. It is titled Mr Bumble Improvements -Phase 3, dated 09/10/13 04.38pm, there you will see a picture of the rear of a Smiths tachometer, It is from a newer car, however it may well be the same as your tacko.
