0 members (), 215 guests, and 91 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Originally Posted By Johnbbank
I've noticed that my tacho occasionally sticks (even with the ignition off) at about the 1500 rpm mark. Is this one of those "they all do that sir" or should I get it looked at? Thanks
My tacho did this after about a year, eventually the fault hardened and the Multi-function (relay) Unit was replaced.
I still get the sticking needle when I turn the car off. It clears if I turn the ignition switch on the off, so I no longer worry about it. To me it seems as if something is not earthing when the ignition is switched off.
Ian
[/quote]
Hi, have a look at one of DaveW's posts. It is titled Mr Bumble Improvements -Phase 3,
dated 09/10/13 04.38pm, there you will see a picture of the rear of a Smiths tachometer,
It is from a newer car, however it may well be the same as your tacko. [/quote]
Thank you very much! joy
Tomorrow I´ll have a look - or should I say I´ll try to feel behind the dash?
This forum is fantastic!!
But how did you remeber this post? sherlock
Originally Posted By bmgermany
But how did you remeber this post? sherlock [/quote]
I some write useful information in my little black book, which I look up from time to time.
Ian
Thank you for all your help. Have a sunny Morgan weekend.
