0 members (),
271
87
Topics49,847
Posts837,389
Posts: 430 Likes: 2
Posts: 430 Likes: 2 |
Some of you must have had the issues I faced until the end of last year : sidescreens coating would start crackling after some time (one year on mine to be precise). After lots and lots of complaining to my London dealer, I finally got the car to go back to Malvern for some important checks (including speedometer fix) and got want I'd always asked for: anodized aluminium frames. Of course it took some time as they had to make specially designed ones (?). But the result is quite pleasing: no more crackling! Problem solved! The guys up in Malvern also took the opportunity and fitted seals to keep sidescreens in contact with windscreen. Top notch & thanks MMC !!!
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
Posts: 1,103 Likes: 17
Posts: 1,103 Likes: 17 |
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Were these the black coated sidescreen frames?
Posts: 430 Likes: 2
Will, I'll try to see what I have in stock... I'll send more once I get vMog back from Williams in 2 week time ;-)
Posts: 430 Likes: 2
Dave The faulty ones I had were silverish grey painted frames.
That's interesting because I thought the two options were anodised, or black.
Posts: 430 Likes: 2
Not on 4strs, quite unfortunately...
Posts: 234 |
Well done vMog, top marks for perseverance ! I had the same problem of crackling on the sidescreens. After my experience of getting other issues resolved (including faulty speedo like yours), I thought I'd be wasting my time pursuing the sidescreens. I spent several days over Christmas stripping the coating off and am pleased with the result, but the aluminium is not protected now and takes a bit of maintenance to keep it looking good.
2019 M3W
Posts: 430 Likes: 2
Richard, did you get your speedo fixed? MMC did fix the problem you should ask them.
Posts: 234 |
Yes they replaced speedo no problem, thanks for asking. It was their attitude to later issues that hacked me off but I won't repeat them on here again.
2019 M3W
