1 members (Jack Noir), 172 guests, and 156 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,289
Smed., Spanner Juggler
Page 3 of 19 1 2 3 4 5 18 19
Sept 2015,6000 Kilometer, not noise up to 120 Km/h (max. Speed Swiss Street)
Chris this is a great thread. After so many "moving on" I've been wondering how many of us were still flying our M3Ws, and this is the perfect excuse for a nice headcount thumbs
Plus, it is a very interesting survey, I hope you or someone take it to the attention of the factory.
Many thanks! smile
Originally Posted By 1903Chris
Chris: 2015 Brooklands; all standard parts; 3000 miles; original BB; noisy 60-70mph
Hi 1903Chris (you're not 113 years old are you? grin2 )My M3W is also a Brooklands (#33) and there are a few more within the TM community, it'll be good for info sharing in what's specific to our cars smile
2010 Morgan +4
2014 M3W Brooklands
To be raced
Bunny | 2012 | 3900 | n | Supermax | y | Redline Shockproof
Andy
le Asbo du Bling
le Asbo du Bling
2012 NVN fitted. 6000 miles
Had the original BB changed early in ownership and factory sprocket upgrade.
BB is generally quiet but last week I adjusted the belt and it was noisy. Let the tension off a bit and it's fine again.
Maybe we need to ask about belt tension as well?
Slowly going green
JMD Offline
Marian; April 2012; initial very noisy BB replaced after 1500-2000 miles; Current has done 6-7000 has been pretty quiet but noise seems to be increasing on moderate loads as (3rd) aluminium sprocket reaches end of life; no NVH kit (have new/replacement (hybrid) chassis); oil as supplied by Morgan/dealer.
2013 M3W
Noise starts around 45 mph
12000 miles
No NVH
Original aluminum sprocket (pitting not bad)
Front BB shaft seal leaking (again)
2013 M3W
2025 Plus Four
Chris99 Offline OP
Good stuff – keep the info coming.
Now up to 25 responses with 14 noisy and 11 quiet
Of the 14 noisy:
12 are 2013 or earlier, kwb is 2014 and 1905Chris a 2015 (Brooklands)
6 have the NVH, 8 do not (assuming hbatts does not.)
Pretty much all the noise is when the BB is hot and somewhere in a 45 – 65 mph speed range
5 are still noisy with Redline Shockproof oil (1 is quiet)
Of the 11 quiet:
7 have NVH and 4 do not
So some further observations
The noisy BB is speed and temperature dependent which I think confirms that resonance is a big factor.
The Redline Shockproof does not seem to cure it and the NVH kit has a mixed impact.
Belt tension may be a factor with asbojohn, MichaelH and MOG42 reporting going quiet with reduced belt tension, however Laurens, nadvys and RogG still have noise. Maybe you guys could let us know the new tension?
There are a couple of responses which could possibly be sprocket rather than bevel box noise – they can sound similar and be speed/load dependent.
And as an aside, there are a lot of boxes being changed for front seal failures!
Red Leader drive
Whilst the above is all valid data it is somewhat subjective. Noisy to me, is different to that of my son and the belt tension is another variable that is subjective. A tough subject.
Not very scientific but my belt tension.
In the middle of the belt there is 15mm of vertical movement whilst apply minimal force, alternatively I can twist the belt 40 degrees with some force. Prior to slackening the belt there was only 5mm maximum movement.
These results seem to pointing to the fact that temperature is causing problems with clearances and hence gear noise or insufficient preload of the pinion bearings, as the survey indicates the noise is worst when the bevel box is hot causing differential expansion between the aluminium housing and the pinion shaft. Not knowing the dimensions of the bevel box but If the bevel box is running at 120 deg C the pinion bearings are 50mm apart then the differential expansion cold to hot could be 0.06mm (0.0024 inches) which could be enough to upset the preload.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
JVS Offline
JVS 2012 M3W
Bevel Box had very little oil in it when I drained it after 500 miles - it was getting noisy.
over six months I changed the oil every hundred miles to get the crap out of the box - until the oil was a clear Red color
(used Redline Shock Proof Red oil) Now 8,000 miles on the unit.
Now the box gets noisy until I change the oil which brings down the noise.
Basically you need to keep fresh oil in the box to keep it quiet.
looks like a rebuilt to happen once the oil changes don't work in keep the unit happy.
would love to see a vendor make an upgraded unit
maybe even chain drive.
Redline is the real deal when it comes to thick lubricant
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
