Topics49,870
Posts837,668
Posts: 135 |
I currently have the Hexagonal knock off nuts that secure my wire wheels.
I am thinking of changing to the spinner type with 2 ears for appearance reasons.
Are the 2 eared spinners just as secure and reliable? are they any harder to secure or remove?
2019 M3W 110 Anniversary Black Previous: 2005 Plus 8
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Yes, just as reliable and no harder (or easier!) to get on or off!!
Cheers!
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The grip of the spinner on the wheel is greater if the wheel is painted or powder coated. Access to the spinner varies according to wheel offset. I changed to triple eared spinners on my 4/4 Anniversary because the earless were hard to remove from the black wires. But my Roadster with deep dish stainless wheels - no problem removing earless spinners.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
probably not a lot in it in terms of ease of removal, but i prefer the hex set up simply because i can use a civilised spanner rather than that brutish whacking with mallets malarkey..
For looks, the eared spinners every time.
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
probably not a lot in it in terms of ease of removal, but I prefer the eared spinners simply because I can whack them with a bloody great mallet rather than that soppy spanner malarkey. For looks, the antique brass hex nuts every time.
Tim you are such a brute
Posts: 2,583 |
I went for hex as they are less easy to remove as "souvenirs" - mind you my car is used a lot and parked all over the place.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
I changed to spinners as I couldn't get the rear hex nuts off. I left that to my friendly dealer, Krazy Horse, who told me they had a real problem getting them off. I was always afraid of damage to the wings when using that daft little spanner whereas now, I ( well the car ) has the good looks and I can wack them on and off with a Thor hammer.
Posts: 4,654 Likes: 124
Posts: 4,654 Likes: 124 |
I knocked off my two front ones today (two ears) with the Thor - first time for ages, to clean the inner wheels and a regrease.
Quite easy - Think I will check them in a few days to make sure I don't become a M3W.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
GaB
Unregistered
GaB
Unregistered
I changed to two-eared spinners some months ago, after struggling to remove the original hex nuts without resorting to a hair dryer! They go on and come off easily, as Robbie says. They also look soooo much better ! Except now I have four redundant 'Morgan' hex nuts, and I don't smoke, so no use as ash trays around the house. Is there any other decadent use you can put them to?
