7 members (CooperMan, sprinty, Graham, G4FUJ, Morganmike, DaveW, MJF, Mike D), 265 guests, and 144 robots.
+8Rich 75
Topics49,869
Posts837,658
Moggo
Glenn,
Keep the "old" hex nuts so that when you sell the car you can swap them back and save hundreds of pounds buying new ones.
Reg
GaB
Unregistered
GaB
Unregistered
A splendid suggestion Reg.
Thank you !
Yep , trouble removing Hex and the lure of flashy two eared spinners and a big discount at Williams did it for me ! Really like spinners , what other cars have such evocative equipment , rare classics !
Originally Posted By Mike Hughes
Two (or three) eared spinners are the way to go.
You can't do this with a hex version.
https://www.youtube.com/watch?v=lLuNstLjP1c
Excellent feature of the 007 DB5. thumbs
Mind you, they had copied it of Bodicea.....
Giles. Mogless in Paris.
May not still be the case but in the 60s the law was changed to require spinners with ears to be changed for the nut type. At the time I had a Spitfire with wire wheels long sold (2094KW if anyone has it) but I still have the ear nuts we removed in the loft.
Originally Posted By lowebird
I changed to spinners as I couldn't get the rear hex nuts off. I left that to my friendly dealer, Krazy Horse, who told me they had a real problem getting them off.
I was always afraid of damage to the wings when using that daft little spanner whereas now, I ( well the car ) has the good looks and I can wack them on and off with a Thor hammer.
It took two experienced mechanics quite a while to remove my wheels today, the hex nuts had been tightened so much.
GaB
Unregistered
GaB
Unregistered
I couldn't remove mine either - I resorted to a hair dryer to warm them up to free them.
Hence the change for me to two-eared spinners, which I tighten/remove with a rubber mallet.
I was aware that they tighten themselves as you drive along, but surprised that they could be that tight.
I've only ever had them get that tight when the hub was spun. Something to check if they're a real problem getting off.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
