1 members (+8Rich),
352
93
Topics49,869
Posts837,666
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Glenn, Keep the "old" hex nuts so that when you sell the car you can swap them back and save hundreds of pounds buying new ones.
GaB
Unregistered
GaB
Unregistered
A splendid suggestion Reg. Thank you !
Posts: 5,587 |
Yep , trouble removing Hex and the lure of flashy two eared spinners and a big discount at Williams did it for me ! Really like spinners , what other cars have such evocative equipment , rare classics !
Posts: 8,646 |
Excellent feature of the 007 DB5.  Mind you, they had copied it of Bodicea.....
Giles. Mogless in Paris.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
May not still be the case but in the 60s the law was changed to require spinners with ears to be changed for the nut type. At the time I had a Spitfire with wire wheels long sold (2094KW if anyone has it) but I still have the ear nuts we removed in the loft.
Posts: 1,461 |
I changed to spinners as I couldn't get the rear hex nuts off. I left that to my friendly dealer, Krazy Horse, who told me they had a real problem getting them off. I was always afraid of damage to the wings when using that daft little spanner whereas now, I ( well the car ) has the good looks and I can wack them on and off with a Thor hammer. It took two experienced mechanics quite a while to remove my wheels today, the hex nuts had been tightened so much.
GaB
Unregistered
GaB
Unregistered
I couldn't remove mine either - I resorted to a hair dryer to warm them up to free them. Hence the change for me to two-eared spinners, which I tighten/remove with a rubber mallet.
Posts: 1,461 |
I was aware that they tighten themselves as you drive along, but surprised that they could be that tight.
Posts: 145 |
I've only ever had them get that tight when the hub was spun. Something to check if they're a real problem getting off.
'61 +4 DHC '70 4/4 '80 4/4 4seater
