0 members (), 215 guests, and 91 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#366140 23/05/16 03:30 PM
Rog G Offline OP
Would someone who has the latest Cambelt cover, with the two horizontal slots cut in the front face be kind enough to measure them and tell me the width of the slots and both of their lengths.
Thanks
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
WW11 MOG
WW11 MOG
There is a square hole cut out in the underside also
Rog G Offline OP
I was aware of the one underneath. Thanks
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
2.3 mm wide. The top one is 76mm in length. The bottom one is 51 mm in length.
The big hole in the bottom is 57mm long and about 9mm wide (couldn't get my calipers in there because of the license plate bar which I chose not to remove!).
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Rog G Offline OP
Thanks Ken, just what I needed.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
The slots are immediately below the raised portions on lower part of cover casting. Careful work with a Dremel and cutting disc should make a neat job.
Note that the latest casting has spacers to mounting bolt points built in, saving the need for spacer washers.
You could always use the confederate cover, it has two slots down low.
Regards trevorv
and on top of that, the confederate cover is beautiful!
Krod #367118 27/05/16 12:24 PM
Q
Q
I think it looks cool but too modern for the Morgan.
I can see that but it also fits the Steampunk look which I see in our cars.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
