4 members (RichardV6, BLUE+4, TBM, Bilymog), 308 guests, and 35 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,332
Christoph
Page 1 of 6 1 2 3 4 5 6
#366109 23/05/16 01:28 PM
I was driving 8% uphill in a tunnel at about 80 km/h. Temperature in tunnel about 15 degrees celsius. Quite a surprise that the exhaust is glowing redhot as I was far from pushing the throttle.
Have added a pickture as a file (if I succeded).
M3W
Pix came through. No surprise at all. This is the reason that nice stainless finish will eventually turn black. This is also a good reason to tape the exhaust with a fiber glass tape. When you come to stop after a hard run the heat from the pipes will try to soften/melt the turn signal indicators!
SBM Offline
Brilliant photo, though..!!
thumbs
On a cold morning in the dark the exhausts glow red on tick over Looks great
I guess you have stock pipes ?
They are very restrictive and cause excessive back pressure which in turn causes them to heat up.
Lord knows what it is doing to the engine.
Either drill out the baffles as some have done on here or fit a less restrictive pipe , available from Morgan , G56 .
I would also imagine that the ECM has the system running VERY lean. The M3W has to meet emission standards.
Here in Missouri there are no emission sniffers at inspection time. In some states cycles don't even get inspected.
If possible due to your home location, a reprogram of the ECM would be a big help with glowing pipes and performance.
Dan
In the UK the M3W is exempt from emission testing, as I found after taking mine for its MOT and it really struggling to pass a test that it should not have been put through in the first place.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
From talking to people who have run them on the dyno, they actually run quite rich as the mapping tries to compensate for the excess heat. Counter-intuitive perhaps, but the standard mapping seems to match less restrictive exhausts better than the standard pipes.
+1
With the MMC Stage 1 the plug colour looks pretty much spot on so the mixture must be about right.
Red Leader drive
Unfortunately the ECU is locked so although you can use the S&S ProTune software to look at what's going on you can't save any changes.
Red Leader drive
