Topics49,837
Posts837,286
Posts: 92 |
Just thought an update was in order, thanks to everyone for their contributions and advice.
Ended up changing the hub for a later type with a larger offset, also replaced the original aluminium sprocket for a Supermax. Remarkable transformation - belt runs cleanly on the new sprocket, plenty of clearance to the tyre. Belt is now loosely tensioned (just so it doesn't slip on hard acceleration). In my M3W I had become accustomed/de-sensitised to a whole array of mechanical noises and vibrations, from both the front and back. I suspect that my belt issues had been undiagnosed from new - judging by the wear on the wall of the tyre (only just done 3000 miles). By the time it came to me the MMC warranty had long passed. I took the opportunity to drain and refill the BB (Millers EP140) at the same time Now the only noise I hear from the rear is an acceptable mechanical 'whirr' from the BB and the hum of the belt. I have to say I'm really pleased, couldn't/wouldn't have done it without the encouragement of the TM forum and especially Calum's excellent write up. Just one other question - has anyone given a thought to the fact that the Supermax overlay sprocket has one less tooth than the MMC standard one (64 to 65 I think). Does this effect the gearing in a beneficial way?
Regards Andrew
M3W 986 3.2S Frogeye Midget 1275 BMW i3S Tesla Y New Ionic 5N BMW R12 Nine T BMW K1300S Jet 200
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Depends what you mean by beneficial. It will very slightly lower the ratios so in 5th you will have about one third of a mph less per 1000 rpm. Doubt you would notice the extra acceleration through the gears though.
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Stock is 66 teeth, SuperMax is 65. I find no real seat of the pants difference in acceleration.
