5 members (scortroadster, SteveT, Luddite, Sir Percival, Image), 325 guests, and 96 robots.
Sagging Hood
Topics49,859
Posts837,479
#367232 28/05/16 07:01 AM
E
exbiker Offline OP
E
Hi, Has anyone used a Bluetooth obd2 reader and their mobile phone to read codes/engine data etc.
I notice you can pick them up for approx. £5.00 on a well known internet site!
Any problems or advise welcomed, cheers,
Ian
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Yes but for I phone you need the wifi version
Works very well
E
exbiker Offline OP
E
Thanks John, I don't have an I phone, I have an android so Bluetooth will be OK, cheers, Ian
Now Ex-Mogger!
have one running on bluetooth and the Torque app.
The app is great especially if you flash the cash c. £3 for the upgrade.
E
exbiker Offline OP
E
Hi John, what does the upgrade give you?
Ian
Now Ex-Mogger!
The basic I think only lets you read & cancel error codes.
The upgrade gives you recording & tracking functions. Look on google play to be sure
E
exbiker Offline OP
E
OK John, I'll look it up, cheers, Ian
Now Ex-Mogger!
I use a Kiwi wifi one for my IPhone and use the DashCommand app - have for the last 3 years on my Elise - Brilliant you can read and clear codes and use it as a heads up dash board when driving, which was my main use as the Elise dashboard is hard to see normally . I even designed a simple to read dash for each model of Lotus Elise/Exige but there are lteraly hundreds of pre designed dashes you can choose from if writing code is not your thing, and once you buy the app the dashboards are all free downloads. I might rewrite a simple dash for the Morgan one day as it will only need the logo, the Temp warning and the Redline parameters adjusted to be good to go.
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
My cheap e-bay Bluetooth OBD device (android)failed to work because my 2014 GDI Plus 4 uses a recent Ford protocol. It no doubt works on older cars. I got one from the States which does read the latest Ford OBD protocol called "OBDLink MX". That does work.
I had before the dongle a cable hand held device & that didn't work on the Roadster.
I understood at the time that Fords were often tricky to find a working reader
