Topics49,871
Posts837,684
Posts: 121 |
Hi I have a 1965 2 seater plus4 I recently replace the braking system they still squeak any thoughts
Posts: 1,947 |
With copperslip, lightly grease the backs of the pads. If you've done this, there are anti-squeal shims for the calipers fitted to a 72 4/4 so there is a good chance you have the same calipers. And if so, give them a whirl.
Posts: 121 |
thank you I purchased the shims
Posts: 121 |
the lucas shims worked like a charm no more noise easy install
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
the lucas shims worked like a charm no more noise easy install They're also worth replacing from time to time as they weaken.
Richard 1976 4/4 4 Seater
Posts: 121 |
