Morgan Aero 8
0 members (), 361 guests, and 76 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
Page 6 of 6 1 2 3 4 5 6
Well I did 80 miles this evening for the hell of it through sunset...... Totally reliable
Formerly known as Aldermog
Adrian,
had a look at this seal on both the nearside and off side.
On the near side door the seal is fitted in a slightly different position in relation to the edge of the door than on the off side.
There is room on both doors to run a double strip, one closer to the edge than the other.
I think it is doors off and re-fit the D section seal!
Drive on the Wild Side
No need to remove doors, if you hold them open sit on ground then it is possible to carefully fit the D seal, also saves a lot of time and effort. cheers
Adrian
kin Offline
Originally Posted By Shooter
The issues I've had with Aero's have been caused by water ingress or driver error.
I would imagine that the electrical issues I had with the door window mechanism on the S3 and S4 were down to the actuators getting wet, the dials in the S4 misting up down to water getting in behind the dash.
A lot of people in the past have said their Aero's were watertight. I have always taken that with a pinch of salt but they may have been the lucky ones or not used the car as a daily driver in all climates :-)
Agreed, I had a S3, did 10K miles in the first year, had major electrical issues by water ingress, mainly due to bad design and poor workmanship.
There was no drain holes in the door, so rain water collected inside the door drowning the electrics, worse of all, the plumbing for the screen wash came adrift behind the dash, so every time I push for screen wash, it squirted water behind the dash causing massive electrical shorts.
But I still love the Morgan, I recently looked at the latest Aero8 in a dealership, much better, at least it now has drain holes built into the doors smile
Unfortunately when the salesman try to open the boot, the boot was stuck, only after a bit of faffing around with one finger keeping on the boot release button while the other hand wriggling the boot lid, it finally popped open.
One must wonder what happens if I needed to refuel, and the boot refuse to open!! confused2 ooo
Do I use a crow bar to lever it open, oh dear.
Kin, like the Ferrari, there are manual boot release cables so you don't need the crowbar :-)
Aero 8 GTN. #10
