2 members (Ian B, ScotiaSteve),
310
105
Topics49,860
Posts837,485
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Several plastic buckets one with a new sponge and some car cleaner ! depending on how dirty or just warm water and a second bucket to rinse out the sponge ( grit sticks in sponge and scratches the car ) . After washing it wash out buckets then do the same with a chamois leather . Then get the wax out HINT HINT .
GaB
Unregistered
GaB
Unregistered
It's a hand job for me (no pun intended!). A bucket, shampoo and a sponge. Clean water to rinse and dry off. All done in less than 30 minutes. Polishing afterwards, that's less than an hour in all. Perfect.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I just put a decorators plastic drop sheet over the engine and close the bonnet (using the clips to hold it in place). Works well enough...with the engine cold of course! That's what I do I've never washed the bonnet without covering the engine as when I first got the car a couple of years ago there was heavy corrosion on the spark plugs which made me think that it had been washed without care in the past
Go to. How to wash your car 21-04-11 plenty for you to read.
Posts: 5,587 |
Just treat her like any other mistress , give her a good sponging and lots of lather , followed by some gentle stroking and caressing !
You missed out the most important bit . AND SPEND LOTS OF MONEY ON HER.
GaB
Unregistered
GaB
Unregistered
...and the Mog?
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I never use a sponge, I use mitts, currently Meguiars lambswool. 2 buckets, one with shampoo and second a rinse bucket for mitt. Spray car first with pressure washer keeping a decent distance, this softens dirt. Shampoo as above. Rinse with pressure washer. Dry with towel and air blower in beading area,nooks and crannies. Polish and wax when needed. Autofinesse Triple between waxes. A sponge can collect bits of grit and drag them over the paintwork, a lambswool mitt tends to pick them up and "absorb" them for rinsing out. This minimises "swirl marks" but not completely. Bugs, tar removed before shampooing. Bird poo washed off gently asap, preferably before it bakes on! No hard rubbing as it can be gritty.....
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Depending on your intentions with cleaning the car there are lots of good ways to proceed. Many have been suggested here. Another suggestion, however, used for my show cars, is not to use tap water. Water spots come from minerals in the water. Use only distilled or purified water (e.g. no minerals) to a get a spot free clean.
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 467 Likes: 1
Posts: 467 Likes: 1 |
I was caught out recently using a gritty sponge. the whole rear panel, drivers side, visibly scratched. took it to Bicester specialists for a quote but never heard back.
1997 +8
