0 members (), 273 guests, and 51 robots.
Topics49,860
Posts837,486
Jonny72
Page 2 of 4 1 2 3 4
PaulV Offline OP
Harley do some different 19inch wheels, but I'd be wary of using a bike wheel - they have different loads (mostly perpendicular to the wheel, not lateral like in a 3 or 4 wheeler). Example (not one I'd consider, but anyway! smile ) below...
Ace wheel discs are still available, like the Rosengart but both faces of the wheel.
http://www.fiennes.co.uk/Parts/Catalogue/O/OB
Tim
Just finished talking to Will fiennes.
He would be very interested in getting the parts for a morgan 3 wheeler.
He needs to see a car up close to take measurements.
Fitting if parts are avaible in the order of 30minutes.
Cost not cheap, depending on volume, in the order of £700 for both wheels.
He's based in west oxfordshire.
PaulV Offline OP
Originally Posted By rockabilly john
Just finished talkng to Will fiennes.
Cost not cheap depending on volume in the order of £700 for both wheels.
Presumably these are wheel disks that mount to the current wheel? Interesting. I'm not far from him and its a nice drive down from Burford (past Cotswold Wildlife Park)... maybe I could drive out there one evening....
To get the look right each disc is made up of 4 pieces which bolt together and then there are 7 cross pieces which lock it all together.
Yes, they encase the current wheel.
That would be very helpful PaulV.
John.
Y
Y
the disc solution is really a good one, you can paint it , polish , sand it and remove it if you want, the cost for made the disc is fairly cheap if 15 peoples want it i can do it easily (in fact my subcontractor)
We need more details Yann.
Where are you? Can you give an indication of price?
Y
Y
hi for do this you have two way to do it , one is cut the ring and press it depend on the thickness you will need between 100 to 300 ton hydraulic press, the second way is use a square sheet and cut after it's more accurate but also the price is not the same more time consuming and human manipulation.
the cost is based on the quantity, but i hav 15 peoples want that made 60 disc (2 by wheel) in my eyes that will never be more than 100 US$ (surely lower), after that have an other cost witch i can't fix it now is the treatment will be asked for: Paint, polish , sanded , chrome and so on
Can be metal or alloy , but the best it's Alloy because no rust and more easy to maintain
i am in Singapore, my subcontractor (and a friend) made part for Roll & Royce plane so i have no doubts about the quality
Voila voila
Y
Y
this disc for is harley a friend of mine do some years ago, i help him to develop it
Are you working in Singapore? I will be holidaying there in September or October. It would be nice to meet!!
Page 2 of 4 1 2 3 4
