1 members (Chad Wilson), 225 guests, and 42 robots.
+8Rich 65
John V6 61
DaveW 55
9,215 Registered Users
Wet Brakes
by IcePack - 27/07/25 03:34 PM
The Stanley Tour 2025
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Topics48,353
Posts813,192
Members9,215
Ivan in Doha, moggin
#379394 23/07/16 07:26 PM
Hi I have a 1965 plus4 2 seater my front indicator is out I have the replacement how do you get to it ???? thanks in advance
If it's just the bulb you are changing then just remove the chrome bezel at the base of the lens from the rubber seal, which will allow you to then pull the lens out . Underneath is the bulb, push in and turn a small amount anticlockwise and then pull out. If its been there for a long time it may well be very corroded and you may have to replace the bulb holder complete but that's easy as well with just a couple of nuts which will probably snap off anyway! Make sure the bulb holder is well earthed.
thank you that worked like a charm, I'm surprised these lamps don't fall off as your driving
