7 members (TBM, GrumpyPa, Morganmike, Alistair, DPEvans, ChrisMorgan, piquet),
290
Topics49,842
Posts837,331
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Hi all! Got into my plus 8 on Friday evening to drive down to TOTH and wouldn't start! Never failed to start first time in all the years I've owned it. 1995 3.9 EFI, battery strong, turns over fine but won't fire. Ignition light etc. not lit just the yellow battery symbol light. Cause probably quite simple but before I dig out all the meters etc and start crawling under the dash I though I'd ask the experts on here. Any advice appreciated!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Immobilizer? Battery in key fob??
Richard 1976 4/4 4 Seater
Posts: 5,587 |
Could be various things , can you smell petrol ie is petrol getting to the injectors , can you hear the fuel pump ? In this case it will either be a duff fuel pump if you've never had one go or the fuel relay (I had this two weeks ago) or even the 30amp fuse to the fuel pump.
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
After checking the basics, check the ignition control unit. I had a similar problem and this was at fault. Easy way to check is to get a spare plus, pull a lead, connect the spare plug and earth. Then get someone to crank the engine and if theres no spark, its likely to be this unit.
Martin (Deano)
Posts: 5,210 |
Has it run out of gin?
Has it run out of gin? Motion potion!
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- good luck with getting her sorted Brian Great to meet up with you and your good lady at TOTH James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
+8 4.8
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Taff YOU SHOULD BE ABLE TO HEAR THE PUMP: I puzzled over this for three weeks until I changed the relays on the firewall. Instant start afterwards.
