5 members (piquet, DirkM, MJF, How, BobtheTrain), 160 guests, and 53 robots.
Posts837,249
#379972 25/07/16 11:29 PM
Taffmog Offline OP
Hi all! Got into my plus 8 on Friday evening to drive down to TOTH and wouldn't start! Never failed to start first time in all the years I've owned it. 1995 3.9 EFI, battery strong, turns over fine but won't fire. Ignition light etc. not lit just the yellow battery symbol light. Cause probably quite simple but before I dig out all the meters etc and start crawling under the dash I though I'd ask the experts on here. Any advice appreciated!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #379983 26/07/16 01:38 AM
Fuel line?
Taffmog #379984 26/07/16 01:44 AM
Immobilizer? Battery in key fob??
Taffmog #379988 26/07/16 05:59 AM
Could be various things , can you smell petrol ie is petrol getting to the injectors , can you hear the fuel pump ? In this case it will either be a duff fuel pump if you've never had one go or the fuel relay (I had this two weeks ago) or even the 30amp fuse to the fuel pump.
Taffmog #379991 26/07/16 06:08 AM
After checking the basics, check the ignition control unit. I had a similar problem and this was at fault. Easy way to check is to get a spare plus, pull a lead, connect the spare plug and earth. Then get someone to crank the engine and if theres no spark, its likely to be this unit.
Martin (Deano)
Taffmog #379994 26/07/16 06:28 AM
Has it run out of gin? hide
Roger
Motion potion!
Taffmog #380012 26/07/16 08:14 AM
- good luck with getting her sorted Brian idea
Great to meet up with you and your good lady at TOTH thumbs
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Taffmog #380034 26/07/16 09:25 AM
Fuel pump relay (again)?
+8 4.8
Taffmog #380042 26/07/16 09:44 AM
Taff
YOU SHOULD BE ABLE TO HEAR THE PUMP: I puzzled over this for three weeks until I changed the relays on the firewall. Instant start afterwards.
