0 members (),
336
Posts837,277
Posts: 1,947 |
My Fairbourne screen is made from Lexan, according to this its conditionally resistant to petroluem & resistant to benzine & ethyl alcohol. http://www.eplastics.com/Plastic/plastic...-Polycarbonate. Tim
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Went out with my M3W, on the way back I got the fueltube leaking in the front which sprayed fuel on the driver windshield. It took only 30 seconds for the windshield to be completely crackeled  ...so I will need replacement screen. The Fairbourne GTS screen would be an option  ...does anybody know if the Fairbourne is more fuelresistant than the Morgan factory one? If not, I would stay on the original ones as it becomes less expensive to replace only the brocken one....otherwise having a fuelresistant one would be a nice upgrade in case an other leaking came up... Sorry to hear that. I too have a standard Fairbourne screen though, and understand it to be made of Lexan. On my boat I have a Lexan fuel filter bowl and tank sight glass so would tend to confirm TimG's comments. BTW if you prefer to stick with originals I have a pair of totally unused ones available for half factory price.
Posts: 342 |
Thanks Tim & Richard for the quick reply, that good news...  I havent seen the GTS screen on the Fairbourne website so I guess that I give them a call to order one....hope they export to Luxembourg. @Richard, nice offer, will keep that in mind but I probably go for the Fairbourne screen.
Cheers, Georges
Posts: 1,947 |
Georges the GTS screen is about 50mm lower & a bit narrower than the GT screen.
Tim
Posts: 6 |
I have seen a Fairbourne screen suffer the same problem, so I guess the material is the same. Polycarbonate I seem to recall from the wrapper on mine.
Posts: 342 |
I have seen a Fairbourne screen suffer the same problem, so I guess the material is the same. Polycarbonate I seem to recall from the wrapper on mine. Hmmmm  ,...that changes the game again...I probably switch on the Brookland aero screens...have to check if they are 'street legal' @Tim, thanks for the mesures
Cheers, Georges
Posts: 342 |
Just ordered two 'aero brooklands' Windshields, laminated glas price about 70£ and looks cool like seen on Raphael's and the 'SteemPunk' M3W pictures Black Adder posted Thanks all for your helpfull and kind ideas  (on of the reasons I love this forum)
Cheers, Georges
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The current Fairbourne screens are made from Lexan Marguard Polycarbonate I believe. This is a chemical resistant material and is also scratch resistan. My current Fairbourne screen is made from this and is very good. My original, early, Fairbourne screen was made form something else, not so scratch or probably chemical resistant and was replaced FOC. I think the Fairbourne screen is one of the better things you can do to a standard M3W to make it more usable.
