0 members (),
282
33
Topics49,841
Posts837,323
Posts: 1,243 Likes: 30
Posts: 1,243 Likes: 30 |
Methinks they could not connect it up. Would need a length of fibre optic & some form of connection. Time money etc.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Someone once said that there was a series of 4/4 wiring looms that had the wire too short so rather than extend it they just left it hanging behind the dash.
Posts: 625 |
Someone once said that there was a series of 4/4 wiring looms that had the wire too short so rather than extend it they just left it hanging behind the dash.  Cheers Peter, that's both amusing as a solution and sad that they would just bodge it on a hand built car
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
John,
My 4/4 has an aftermarket immobiliser (According to Aus. Standards) fitted and the light is under the dash on the right. Guess it is just a convenient spot.
PS Nothing arrived as yet.
Graeme: 2011 +4
Posts: 625 |
John,
PS Nothing arrived as yet. Must be standard for here then  That's Oz post these days - def on way
Posts: 44 |
It really sounds that the battery needs to be replaced. In order to avoid a flat battery I have installed a battery switch. This works excellently. So even if I do not use the car for two month the battery still keeps its power. And as a nice side effect it is a very efficient anti theft measure...
Karsten
2010 Teal Roadster Sport V6
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
Be careful if the car already has such a switch some circuits by pass it like the clock & power to the ECU. ECUs can loose their settings if power is removed. Juuuuuuuust remove the plywood parcel shelf & you can se if it is bypased
Posts: 44 |
Be careful if the car already has such a switch some circuits by pass it like the clock & power to the ECU. ECUs can loose their settings if power is removed. Juuuuuuuust remove the plywood parcel shelf & you can se if it is bypased Hmmh, the battery switch has been installed by a well known Morgan Garage and it works perfectly. And I have no clock... But thanks for your comment. I will check whether or not it is bypassed.
Karsten
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I once had a Triumph Spitfire and a previous owner wired in an under dash light without a fuse. It shorted & that was impressive. Luckily nothing else failed or caught fire.
Old story time..and thread drift alert... I had a convertible Herald 13/60 in my yoof and driving home one evening had the under dash wires drop down from behind the home fitted radio. I leant over at 50mph and used my left hand to tuck them back up & started off what looked like bonfire night..! Lesson learnt...fuses are cheap.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
ECU should not loose anything but trim values that'll be relearned once you drive it again.
