Morgan Aero 8
4 members (IcePack, David_E, PaulJ, DaveW), 316 guests, and 88 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
#382982 07/08/16 02:31 PM
gmcn Offline OP
I would appreciate a little help. The paint immediately surrounding (3mm or so) the two rear reflector lenses has begun to peel of. I cant't see how to remove the less to get at the paint to touch it up. If you have to access the less from underneath the rear then I will need to remove the Librands exhaust as heat shielding material covers the area. On the other hand, from what I can see, it could be that the lenses are mounted on plywood or ash in which case, no worry about corrosion and no need to remove the lenses as I can touch the area up with a fine paintbrush. Anyone any experience of taking the reflector lenses off? Photo attached, it is the lower lenses in the cluster that I am referring to.
Appreciate your thoughts
Graham
Hi Graham
if I am understanding your post correctly,it is the two red reflectors you are referring to and not the actual light clusters ?
If so ,it is good news smile
The rear reflectors have a central screw thread on the back of them and simply screw in to the ash frame.I can't actually remember which way to turn but, going by -
'righty tighty,lefty loosey'
I would assume it is anti-clockwise to loosen them off.
If they are really stuck tight they may have to be sacrificed to get them turning (i.e.. 'Billy Bodgered' - small chisel tapped in the rim 'till they start to loosen pale ) ;new ones are available from the usual suspects if this is the case......
HTH, James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
gmcn Offline OP
James,
Brilliant, as you say good news, thanks for the quick and most helpful reply
Graham
Anyone know what car the reflectors are off ?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
