1 members (Socalm3w),
305
35
Posts837,277
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Hello All, yes today is mot day at 3pm checked all the lights ( yesterday) all aok however today the main is not working ! Horn/indicators / dip /flash main all working but main is u/s so it's the switch anybody know what part it is uncle melvin wants £61 plus vat plus p and p 😠 Part elso078 but ebay is £29 from a mk ii mini ( looks the same ?? ( Help
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Have a look at the one you've got: it's usually just a contact needs bending slightly. Good luck with the MOT!
1972 4/4 2 Seater
Posts: 12,255 Likes: 317
Posts: 12,255 Likes: 317 |
This is a common problem on these switches, MMC in their wisdom didn't fit headlamp relays, so the switch contacts take the full current and burn out. The correct switch is a Triumph part, and they are expensive. you also have to bend the arm in 2 places to get it to fit, which is a bit of a trepidatious experience when you've just forked out 75 quid on the thing. When you get a replacement, do yourself a big favour and fit a pair of relays to save it happening again. There's a set of instructions on how to do it on Morganatica: https://sites.google.com/site/morganatic...m-switch-repair
Posts: 970 Likes: 1
Wd40 sorted the switch at the mot station. Mot passed with no advisories.......phew
Wd40 sorted the switch at the mot station. Mot passed with no advisories.......phew That's a good result! But I would still recommend fitting some headlight relays.
Posts: 5,210 |
Wd40 sorted the switch at the mot station. Mot passed with no advisories.......phew Great result. So the kingpins were ok too?
Posts: 970 Likes: 1
Wd40 sorted the switch at the mot station. Mot passed with no advisories.......phew Great result. So the kingpins were ok too? The guy was an old time mot tester and had tested morgan before. Said there was nothing wrong  with the king pins
