2 members (RichardV6, Chris Cosher), 211 guests, and 37 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Hello All,
yes today is mot day at 3pm
checked all the lights ( yesterday) all aok
however today the main is not working !
Horn/indicators / dip /flash main all working
but
main is u/s
so it's the switch
anybody know what part it is
uncle melvin wants £61 plus vat plus p and p 😠
Part elso078
but
ebay is £29 from a mk ii mini ( looks the same ?? (
Help
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
Originally Posted By stevemag
Hello All,
but
main is u/s
so it's the switch
Part elso078
but
Help
Have a look at the one you've got: it's usually just a contact needs bending slightly. Good luck with the MOT!
1972 4/4 2 Seater
This is a common problem on these switches, MMC in their wisdom didn't fit headlamp relays, so the switch contacts take the full current and burn out.
The correct switch is a Triumph part, and they are expensive. you also have to bend the arm in 2 places to get it to fit, which is a bit of a trepidatious experience when you've just forked out 75 quid on the thing.
When you get a replacement, do yourself a big favour and fit a pair of relays to save it happening again. There's a set of instructions on how to do it on Morganatica:
https://sites.google.com/site/morganatic...m-switch-repair
Wd40 sorted the switch at the mot station. Mot passed with no advisories.......phew
Magwa
That's a good result! But I would still recommend fitting some headlight relays.
Great result. So the kingpins were ok too?
Roger
The guy was an old time mot tester and had tested morgan before. Said there was nothing wrong rofl with the king pins
Magwa
