Posts837,957
Most Online1,063Jun 14th, 2026
So far so good Attempted a 'dry fit' of the folding windscreen tonight to see how it goes and what clearance I have on the scuttle and to see what needs fettling
image.jpeg (97.66 KB, 456 downloads) Sides carefully removed - 1 side at a time so the screen didn't fall image.jpeg (66.06 KB, 442 downloads) Done and folded
I made sure I labelled ever fitting as I took them off as I've heard some horror stories of screens cracking when tightening up a screw too long
image.jpeg (65.13 KB, 438 downloads) Now a bit of a cleanup as there is so much dirt under the screen image.jpg (72.82 KB, 431 downloads) Looking pretty sleek sans screen
Also pleased Morgan left enough slack on the heated screen wires to allow it to fold - I thought I might have to cut them and reattach
Looks like a good job done well. Are you feeling braver to attempt the aero screen challenge yet?
Looks the business!
Looks like a good job done well. Are you feelong braver to attempt the aero screen challenge yet?
Still a bit nervous, I'm going to have to drop the dash however I attach them so I don't damage the veneer
Stewart, well done. A watch point for the aero screens. Even if the feet & the screens miss the windscreen when the windscreen is up the winged nuts that hold the aero screens to the feet can touch the windscreen. I found I left the aero screens on generally so this touching is annoying even if only when the car vibrates. John
Good point, thanks for that John - will double check that one
There are so many potential pitfalls on this little project
I know I found it a scary process to drill into the car.
Well done you! I wasn't aware that this could be done on a heated windscreen.
