7 members (JMcL, cerealsurfer, RichardV6, RedThree, simon8201, Dek, AlyMatt),
307
Posts837,985
Posts: 1 |
I have a 1957 Plus 4 and wondering if anyone has installed a quick steering wheel removal hub?
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
not had much luck in getting further info. on this (for my Aero8),but people speak highly of his other products (hood,wheels,etc.). http://www.superspoke.co.ukMay be worth an e-mail to get prices,etc...? James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 541 |
My M3W came stock with this hub. I highly recommend getting one for your car. As they say "no wheel, no steal."
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 199 |
i have buy one but not yet installed , the quality look really good and every details are well done, at least i don't regrets my shopping
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
These are standard on M3W I think and available for trads from Aero Racing. The splines on the column are different in that they have a locator so you would probably end up having to make a modified steering column. Easier to fit a smaller wheel maybe?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Question is why do you want to remove the steering wheel?
Arwyn
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Arwyn Getting in and out? I had one fitted to a '59 Aston I had - my corpulent physique couldn't make it in out without it.
+8 4.8
I had one on my Lotus and it made entry and egress much easier and it was also a great theft deterrent  James
Most of the kits I've seen require an adaptor to be welded to the steering shaft. The boss then clips onto the adaptor
The trouble on an early Morgan with the long steering column is that it might prevent you dismantling the steering column for overhaul.
Its also a job that requires an experienced welder to attempt - I've just turned down such job on Proton Satria rally car!
As Taffmog suggests, a smaller steering wheel is possibly the way forward!
Posts: 389 |
The German Morgan Dealer Morganpark sales his own steering wheel. These steerings wheel are a bit flat at the bottom (minus 10-12mm) which is not really visible. Maybe this could be an alternative to a new hub and be less complicated. Steeringwheels Pricelist Contact is lars.bubert@morganpark@de Maybe they can provide some information in English if you contact them by mail. BR Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
