Posts837,978
Posts: 82 |
hi all
Have developed a rather fetching crack in my screen on my 96 Plus 8 (laminated, no heated strips). Down in Budapest struggling to find a replacement... How do you all do it? Order a premade one or get one made?
Any help much appreciated... if you have someone local who makes I can have courier bring to Budapest for instance...
Thanks!
Alex
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Good advice here on GoMog. Also read that when fitting electrical tape around the edge helps. Also don't forget that the longer side screw goes at the bottom!
Richard 1976 4/4 4 Seater
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
I had to get mine made by autoglass ( uk firm) they used a cut down Fiat panda car screen.But my car has the tall screen (4 seater car)
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
I have had one made by a local vehicle glass supplier in the UK, it didn't take them long to cut it from standard flat laminated glass using my old screen as a template.
A quick bit of Googling shows Kabelacs Autoglass Non-stop in Budapest offer a 24-hour service, their number is +36 20 990 7161 I don't know if they could help?
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Alex
Follow Tim's advice and find a local supplier who can cut flat laminated glass from a template.
When removing the cracked screen be VERY careful to make a note of where each screw comes from, and number them, or mount them on a cardboard template, or similar. They are unequal lengths and need to go back in EXACTLY the same places , or the new screen will crack again almost as soon as it is mounted in the frame.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Does your insurance not cover it? It would in the UK with a small excess.
1972 4/4 2 Seater
Posts: 82 |
Hi guys thanks for all advice. A chap that works for me (speaks Hungarian) has helped me out and found a glass shop that charges 90 quid for a hand cut piece of laminated. Will take screen over to them and job done. Anyone wants some doing shout!
