8 members (PeterVD, Mogdavid, IcePack, RichardV6, Bishmog, Paul F, Grumpy2, Rog G),
321
41
Topics48,364
Posts813,343
Members9,215
Posts: 574 Likes: 3
Posts: 574 Likes: 3 |
Hey there  I just discovered, my Motor Heat Cover is completely loose. Wanted to tighten the screw, but my metric hex key does not fit. Will I need an inch key - or even imperial key? If yes, what size? And does the black paint on your cover also "break off"? I thought this was just some whatever black plastic material. But I seems to be lexan, with black paint? pete / comet
in love with life. that's it.
Posts: 1,490 |
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 574 Likes: 3
Posts: 1,490 |
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
Presume you mean the urban cooling kit cover? This is attached with 4 setscrews to the fan itself, as to the 2 setscrews which fasten it to the engine I have no idea! I have a full set of Torx, star drives etc and nothing fits properly although some do fit well enough to do and undo. Must be a weird American fitting I suppose! The standard cover looks like a hard fibreglass of some sort, really ugly with a finish that won't polish up at all. MMC simply spray them with black gloss so if yours is peeling off I would suggest simply respraying with a rattle can (?). Keep us informed!
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 50 |
Hi Pete The engine is using inch keys. I bought a set of inch inbus keys to address this topic. The shroud itself is just fixed by the two big screws on top. Best regards Kurt
M3W willow green,Triumph T100,KTM LC4 Adv./Freer.250R, RD250/RS125DX, Alpine A110 Kurt
Posts: 574 Likes: 3
simply spray them with black gloss so if yours is peeling exactly. its peeling/breaking off around the screw holes. the cover itself, without the glossy finish looks like lexan, the material that is also being used for (kitchen-) spatulas. thanks kurt. I ll get some of those tools then! btw, comet gets its first service tomorrow
Posts: 582 |
I believe most of the engine related stuff is SAE and the rest of the car is a mixture of metric and SAE. Good exercise running back and forth for tools. When working on the car I have an old cookie tin I fill with tools.
