Topics49,859
Posts837,500
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Yes Button, I use the lower ride height setting, with the 20mm spacer below the stub axle. It works a treat, and I still have over 100mm of ground clearance so sleeping policemen are not a problem.
I don't understand why your shocks are locking up, the Bilsteins are specifically designed for the kit.How much gap is there between the rebound spring and the stub axle?
Posts: 1,943 |
Thanks Tim, I'll keep loking
Button
Posts: 2,583 |
You have speed bumps on your drive..? Nice pad, Phil..!! Of course being Liz & Phil of the Royle family one must have one`s drive designed to keep the peasants out!
GaB
Unregistered
GaB
Unregistered
Does anyone know if there is any significant difference between the Mulfab front end setup and the New Elms (Rutherford) version?
